3D+t Reconstruction in the Context of Locally Spheric Shaped Data Observation
The main focus of this paper is 3D+t shape recovery from 3D spatial data and 2D+t temporal sequences. This reconstruction is particularly challenging due to the great deal of in-depth information loss observed on the 2D+t temporal sequence. Our approach embed a geometrical local constraint to handle the critical lack of information. This prior constraint is defined by a spherical topology because several applications may be concerned. It allows us to model relevantly the 3D- to-2D transformation that reduces each 3D image into a 2D frame. We then can build a 3D inaccurate inverse reconstruction of each 2D frame belonging to the video, i.e. 2D+t sequence. These inaccurate 3D images are enhanced by gradual motion compensation using a regularity criterion. Results on synthetic data are displayed.
