Land cover, land use and malaria in the Amazon: a systematic literature review of studies using remotely sensed data. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Malaria Journal Année : 2013
Isabelle Dusfour
Ana Paula Corrêa
  • Fonction : Auteur
  • PersonId : 942600
Manoel Cruz
  • Fonction : Auteur
  • PersonId : 942601
Allan Galardo
  • Fonction : Auteur
  • PersonId : 942602
Clícia Galardo
  • Fonction : Auteur
  • PersonId : 942603
Romain Girod
Helen Gurgel
  • Fonction : Auteur
  • PersonId : 853359
Ana Cristina Lima
  • Fonction : Auteur
  • PersonId : 942605
Alana Soares
  • Fonction : Auteur
  • PersonId : 942607
Emmanuel Roux
The nine countries sharing the Amazon forest accounted for 89% of all malaria cases reported in the Americas in 2008. Remote sensing can help identify the environmental determinants of malaria transmission and their temporo-spatial evolution. Seventeen studies characterizing land cover or land use features, and relating them to malaria in the Amazon subregion, were identified. These were reviewed in order to improve the understanding of the land cover/use class roles in malaria transmission. The indicators affecting the transmission risk were summarized in terms of temporal components, landscape fragmentation and anthropic pressure. This review helps to define a framework for future studies aiming to characterize and monitor malaria.
1475-2875-12-192.pdf (433.55 Ko) Télécharger le fichier
1475-2875-12-192-S1.DOCX (21.37 Ko) Télécharger le fichier
1475-2875-12-192-S2.DOCX (20.21 Ko) Télécharger le fichier
1475-2875-12-192.xml (69.95 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
inserm-00834790 , version 1 (17-06-2013)
Aurelia Stefani, Isabelle Dusfour, Ana Paula Corrêa, Manoel Cruz, Nadine Dessay, et al.. Land cover, land use and malaria in the Amazon: a systematic literature review of studies using remotely sensed data.. Malaria Journal, 2013, 12 (1), pp.192. ⟨10.1186/1475-2875-12-192⟩. ⟨inserm-00834790⟩
993 Consultations
1166 Téléchargements
