Antibody Neutralization of HIV-1 Crossing the Blood-Brain Barrier - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue mBio Année : 2020
HIV-1 can cross the blood-brain barrier (BBB) to penetrate the brain and infect target cells, causing neurocognitive disorders as a result of neuroinflammation and brain damage. The HIV-1 envelope spike gp160 is partially required for viral transcytosis across the BBB endothelium. But do antibodies developing in infected individuals and targeting the HIV-1 gp160 glycoproteins block HIV-1 transcytosis through the BBB? We addressed this issue and discovered that anti-gp160 antibodies do not block HIV-1 transport; instead, free viruses and those in complex with antibodies can transit across BBB endothelial cells. Importantly, we found that only neutralizing antibodies could inhibit posttranscytosis viral infectivity, highlighting their ability to protect susceptible brain cells from HIV-1 infection.
Immunologie
mBio.02424-20.pdf (1.74 Mo) Télécharger le fichier
Origine : Publication financée par une institution
pasteur-03246667 , version 1 (02-06-2021)
Paternité
Valérie Lorin, Anne Danckaert, Françoise Porrot, Olivier Schwartz, Philippe Afonso, et al.. Antibody Neutralization of HIV-1 Crossing the Blood-Brain Barrier. mBio, 2020, 11 (5), pp.e02424-20. ⟨10.1128/mBio.02424-20⟩. ⟨pasteur-03246667⟩
33 Consultations
65 Téléchargements
