Approches d'évaluation de l'accès universel et stratégies d’optimisation : Application au cas de l' Afrique centrale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Evaluation approaches of universal access and Strategies of optimization : Application to the case of Central Africa
Idriss Saleh Bachar
  • Fonction : Auteur
This thesis deals systematically with the analysis of the situation of ICTs in Central Africa, it identifies the problems related to universal access and studies ICTs harmonization policies. This analysis then enables the proposal of an integrated target mapping to reduce the digital divide. Not only the different optical and radio broadband technologies are used but described to relate the basic concepts allowing to apprehend the advantages and disadvantages of each technology. This allowed us to propose a methodological approach to modeling the universal access and service indicator coupled with an optimization strategy revealing, on the one hand, the technological gap to be filled and on the other hand, predicting the access level based on technologies to achieve in accordance with the investment policies of the Universal Service Fund. Besides the proposal of this modeling approach, other contributions of this thesis is developing a network model architecture based on radio technologies and proposing a methodology consisting of integrating the various parameters involved in the choice of technologies to be deployed for access and universal service. In addition, it is projected into the future evolution of solutions that leads to hybrid technologies.
Cette thèse aborde de façon systémique l’analyse de la situation des TICs en Afrique Centrale, elle identifie les problématiques liées à l’accès universel et étudie les politiques d’harmonisation des TICs. Cette analyse conduit alors à proposer une cartographie cible intégrée permettant de réduire la fracture numérique. Non seulement les différentes technologies optiques et radio large bande sont mises à contribution mais décrites en vue de relater les notions de base permettant d’appréhender les avantages et inconvénients de chaque technologie. Ceci a permis par la suite de proposer une démarche méthodologique de modélisation de l’indicateur d’accès au service universel couplée à une stratégie d’optimisation révélant, d’une part le gap technologique à combler et d’autre part, prédisant le niveau d’accès technologique à atteindre en fonction des politiques d’investissement du Fonds de Service Universel. Aussi, outre la proposition de cette démarche de modélisation cette thèse apporte une autre contribution en développant un modèle d’architecture réseau basé sur les technologies radio et en proposant une méthodologie consistant à intégrer les différents paramètres impliqués dans le choix des technologies à déployer en vue de l’accès au service universel. De plus, elle se projette dans l’évolution future de la technologie en offrant une ouverture sur les technologies hybrides.
2016LIMO0098.pdf (5.34 Mo) Télécharger le fichier
tel-01495308 , version 1 (24-03-2017)
  • HAL Id : tel-01495308 , version 1
Idriss Saleh Bachar. Approches d'évaluation de l'accès universel et stratégies d’optimisation : Application au cas de l' Afrique centrale. Réseaux et télécommunications [cs.NI]. Université de Limoges; Université Cheikh Anta Diop (Dakar), 2016. Français. ⟨NNT : 2016LIMO0098⟩. ⟨tel-01495308⟩
233 Consultations
651 Téléchargements
