Integrating top-down and bottom-up approaches to design a cost-effective and equitable programme of measures for adaptation of a river basin to global change. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Intégrer les approches "top-down" et "bottom-up" pour définir un programme de mesures cout-efficace et équitable pour s'adapter au changement global à l'échelle d'un bassin versant
Adaptation to global change challenges at the river basin scale requires selecting from demand and supply management measures in a context of high uncertainty on future conditions. Given the interdependency of water users, agreements need to be found at the local level to implement the most effective adaptation measures. Therefore, this thesis develops an approach combining economics and water resources engineering to: select a cost-effective programme of adaptation measures in the context of climate change uncertainty; and define an equitable allocation of the cost of the adaptation plan between the stakeholders involved. The framework developed integrates inputs from the two main approaches commonly used to plan for adaptation. The first, referred to as “top-down”, estimates the impact on the local water resources from different climate change scenarios at the global level. Conversely, the second, called “bottom-up”, starts by assessing vulnerability at the local level to then identify adaptation measures to face an uncertain future. Outcomes from the previous approaches applied in the Orb River basin (France) are integrated to select a cost-effective combination of adaptation measures through a least-cost optimization model developed at the river basin scale. Supply-side infrastructure development measures are considered, as well as demand-side household water conservation measures or irrigation efficiency improvement. The model is then used to investigate the trade-offs between different planning objectives and to identify robust and least-regret adaptation measures. The issue of allocating the cost of the adaptation plan is considered from two complementary perspectives. The outcome of a negotiation process between the stakeholders is modelled through the implementation of cooperative game theory to define cost allocation scenarios. These results are then compared with cost allocation rules based on social justice principles to provide contrasted insights into a negotiation process. The interdisciplinary framework developed during this thesis combines economics and water resources engineering methods, creating a promising means of bridging the gap between bottom-up and top-down approaches and supporting the definition of cost-effective and equitable adaptation plans at the local level.
L’adaptation au changement global à l’échelle des bassins versants requiert la sélection des mesures d’adaptation efficace dans un contexte d’incertitudes élevées concernant les conditions futures. Étant donné l’interdépendance entre les usagers de l’eau à l’échelle d’un bassin versant, des accords sont nécessaires pour mettre en place les mesures d’adaptation les plus efficaces. Cette thèse développe une approche pour : sélectionner un programme de mesures d’adaptation coût-efficace dans un contexte d’incertitudes liées au changement climatique ; et pour définir une répartition équitable du coût d’un tel programme de mesures entre les différentes parties prenantes. Le cadre méthodologique développé intègre les deux principales approches habituellement utilisées pour la planification de l’adaptation. La première, intitulée « Top-down» (Descendante), évalue l’impact de différents scénarios climatiques au niveau global sur les ressources en eau à l’échelle locale. La deuxième approche, appelée « Bottom-up » (Ascendante), commence par évaluer la vulnérabilité au niveau local pour ensuite identifier des mesures d’adaptation qui permettront de faire face à un futur incertain. Les résultats des approches précédentes, appliquées dans le bassin versant de l’Orb (France), ont été intégrés au moyen d’un modèle d’optimisation pour sélectionner une combinaison coût-efficace de mesures d’adaptation, considérant la possibilité de développer de nouvelles infrastructures, mais aussi de mettre en place des mesures d’économie d’eau dans les ménages ou d’amélioration de l’efficacité de l’irrigation. Le modèle est ensuite utilisé pour explorer les arbitrages possibles entre différents objectifs de planification et identifier des mesures d’adaptation robustes et de moindre regret. La question de la répartition du coût du plan d’adaptation est ensuite considérée depuis deux perspectives complémentaires. Le processus de négociation entre les acteurs impliqués est modélisé au moyen de la théorie des jeux coopératifs pour définir des scénarios de répartition des coûts équitables. Ces scénarios sont ensuite comparés avec des règles de répartition des coûts basées sur différents principes de justice sociale évaluées avec les acteurs locaux pour apporter des éléments de discussion au processus de négociation. Le cadre méthodologique interdisciplinaire développé durant cette thèse contribue à combler l’écart entre les méthodes Top-down (descendantes) et Bottom-up (ascendantes) pour informer la définition de plan d’adaptation coût-efficace et équitable à l’échelle locale.
15-0042_Girard.pdf (10.55 Mo) Télécharger le fichier
tel-01567125 , version 1 (21-07-2017)
  • HAL Id : tel-01567125 , version 1
Corentin Girard. Integrating top-down and bottom-up approaches to design a cost-effective and equitable programme of measures for adaptation of a river basin to global change.. Economics and Finance. Montpellier SupAgro; Universitat politècnica de València (Valence, Espagne), 2015. English. ⟨NNT : 2015NSAM0042⟩. ⟨tel-01567125⟩
590 Consultations
1434 Téléchargements
