Computational methods for event-based signals and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Méthodes de calcul pour les signaux événementiels et applications
Xavier Lagorce
  • Fonction : Auteur
  • PersonId : 772448
  • IdRef : 191716731
Computational Neurosciences are a great source of inspiration for data processing and computation. Nowadays, how great the state of the art of computer vision might be, it is still way less performant that what our brains or the ones from other animals or insects are capable of. This thesis takes on this observation to develop new computational methods for computer vision and generic computation relying on data produced by event-based sensors such as the so called “silicon retinas”. These sensors mimic biology and are used in this work because of the sparseness of their data and their precise timing: information is coded into events which are generated with a microsecond precision. This opens doors to a whole new paradigm for machine vision, relying on time instead of using images. We use these sensors to develop applications such as object tracking or recognition and feature extraction. We also used computational neuromorphic platforms to better implement these algorithms which led us to rethink the idea of computation itself. This work proposes new ways of thinking computer vision via event-based sensors and a new paradigm for computation. Time is replacing memory to allow for completely local operations, enabling highly parallel machines in a non-Von Neumann architecture.
Les neurosciences computationnelles sont une grande source d'inspiration pour le traitement de données. De nos jours, aussi bon que soit l'état de l'art de la vision par ordinateur, il reste moins performant que les possibilités offertes par nos cerveaux ou ceux d'autres animaux ou insectes. Cette thèse se base sur cette observation afin de développer de nouvelles méthodes de calcul pour la vision par ordinateur ainsi que pour le calcul de manière générale reposant sur les données issues de capteurs événementiels tels que les "rétines artificielles". Ces capteurs copient la biologie et sont utilisés dans ces travaux pour le caractère épars de leurs données ainsi que pour leur précision temporelle : l'information est codée dans des événements qui sont générés avec une précision de l'ordre de la microseconde. Ce concept ouvre les portes d'un paradigme complètement nouveau pour la vision par ordinateur, reposant sur le temps plutôt que sur des images. Ces capteurs ont été utilisés pour développer des applications comme le suivi ou la reconnaissance d'objets ou encore de l'extraction de motifs élémentaires. Des plate-formes de calcul neuromorphiques ont aussi été utilisées pour implémenter plus efficacement ces algorithmes, nous conduisant à repenser l'idée même du calcul. Les travaux présentés dans cette thèse proposent une nouvelle façon de penser la vision par ordinateur via des capteurs événementiels ainsi qu'un nouveau paradigme pour le calcul. Le temps remplace la mémoire permettant ainsi des opérations complètement locales, ce qui permet de réaliser des machines hautement parallèles avec une architecture non-Von Neumann.
2015PA066434.pdf (51.26 Mo) Télécharger le fichier
tel-01592392 , version 1 (24-09-2017)
tel-01592392 , version 2 (05-10-2017)
  • HAL Id : tel-01592392 , version 2
Xavier Lagorce. Computational methods for event-based signals and applications. Automatic. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066434⟩. ⟨tel-01592392v2⟩
485 Consultations
348 Téléchargements
