Synthèse d'observateurs pour les systèmes non linéaires, non uniformément observables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Synthesis observers for non uniformly observable nonlinear systems
The results given in this thesis deal with the design of high gain observers for some classes on Multi Input Multi Output non uniformly observable nonlinear systems. In a first step, the class of considered systems is such that the dynamics of the state variables is the sum of two terms. The first term is affine in the state and is composed by the product of a matrix, whose entries are nonlinear functions of the state with a triangular structure, by the state vector. The second term describes the system nonlinearities which also assume a triangular structure. The gain of the proposed observer is issued from the resolution of a Lyapunov ordinary differential equation. The exponential convergence of the underlying observation error is established under a persistent excitation condition involving the system inputs and the state of the observer. In a second step, the observer design has been extended to a larger class of nonlinear systems where some state variables may intervene in a non triangular way. The notion of the characteristic indices associated to these state variables is then introduced and it allowed to define an extended triangular structure for which a high gain observer has been designed. Finally, it has been established that the proposed observers can be used as adaptive ones to jointly estimate the system state together with some unknown parameters and an adaptive form of these observers has been derived. The performance and main properties of the proposed observers have been illustrated in simulation by considering many examples throughout this thesis.
Les résultats présentés dans cette thèse s’articulent autour de la synthèse d’observateurs de type grand gain pour des classes de systèmes non linéaires multi-entrées, multi-sorties non uniformément observables. Dans un premier temps, la classe de systèmes considérées est telle que la dynamique des variables d’état est décrite par la somme de deux termes. Le premier correspond à une partie affine en l’état décrite par le produit d’une matrice, dont les entrées (fonctions non linéaires de l’état) ont une structure triangulaire, par le vecteur d’état. Le deuxième terme est composé par les non linéarités du système qui ont aussi une structure triangulaire. Le gain de l’observateur proposé est issu de la résolution d’une équation différentielle ordinaire de type Lyapunov.La convergence exponentielle de l’erreur d’observation sous-jacente est établie sous une une certaine condition d’excitation persistante dépendant de l’entrée du système et de l’état de l’observateur.Dans un deuxième temps, la synthèse de cet observateur est étendue à une classe plus large de systèmes non linéaires où des états peuvent intervenir de manière non triangulaire.La notion d’indices caractéristiques associés à ces états est alors introduite et elle a permis de définir une structure triangulaire étendue pour la quelle la synthèse de l’observateur a aussi été effectuée.Enfin, il a été établi que les observateurs proposés peuvent être utiliséscomme observateurs adaptatifs pour l’estimation simultanée de l’état et de certains paramètres et une forme adaptative de ces observateurs a été générée.Les performances des différents observateurs proposés ont été illustrées à travers des exemples en simulation
2017-LTAIEF-ALI-VOC.pdf (1.39 Mo) Télécharger le fichier
tel-01638200 , version 1 (20-11-2017)
  • HAL Id : tel-01638200 , version 1
Ali Ltaief. Synthèse d'observateurs pour les systèmes non linéaires, non uniformément observables. Automatique / Robotique. Normandie Université; Université de Sfax (Tunisie), 2017. Français. ⟨NNT : 2017NORMC211⟩. ⟨tel-01638200⟩
433 Consultations
326 Téléchargements
