Gestion de l'information embarquée dans des matériaux communicants à l'aide de protocoles de réseaux de capteurs sans fil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Embedded information management in communicating materials using wireless sensors network protocols
Kais Mekki
  • Fonction : Auteur
  • PersonId : 992563
A new Internet of Things area is coming with communicating materials, which are able to provide diverse functionalities to users all along the product lifecycle. As example, it can track its own evolution which leads to gather helpful information. This new paradigm is fulfilled via the integration of specific electronic components into the product material. In this thesis, ultra-small wireless sensor nodes are used for concrete precast field. Indeed, storage of lifecycle information and data dissemination in communicating materials are very important issues. Therefore, this thesis provides a new protocol (USEE) for storing data by a systematic dissemination through the integrated sensor nodes. It guarantees that information could be retrieved in each piece of the concrete by intelligently managing data replication among each neighborhood of the sensor network. The protocol considers in the same set uniformity storage in the whole network, the data importance level, and the resource constraints of sensor nodes. Then, another new data retrieval protocol (RaWPG) is developed to extract the stored information. Castalia/OMNeT++ simulator is used to evaluate the performances of the proposed protocols.
La thèse aborde le problème de la dissémination des informations liées au produit tout au long de son cycle de vie, par l?exploitation du concept de matière communicante. L?objectif général est de stocker dans la matière communicante ses caractéristiques initiales mais aussi l?évolution de ses propriétés durant son usage, en évitant de les perdre lors par exemple d?une transformation ou d?une destruction d?une partie du matériau. Dans le cadre de cette thèse, ce principe est appliqué dans le domaine des préfabriqués en béton, où des n?uds de réseaux de capteurs sans fil sont intégrés dans le béton. Ces n?uds sont alors utilisés pour stocker des informations relatives au cycle de vie du préfabriqué et à sa surveillance sur la phase d?usage. Un nouveau protocole de communication, nommé USEE, a été proposé et permet de diffuser uniformément les informations dans la matière en considérant qu?elles n?ont pas toutes la même importance. Le protocole USEE évite notamment la saturation rapide des mémoires des n?uds de façon à pouvoir stocker un maximum d?informations différentes. Ensuite, un protocole de lecture, intitulé RaWPG, a été développé. Il est adapté à la récupération d?informations uniformément réparties et consomme peu d?énergie. Ces deux protocoles ont été implémentés dans le simulateur réseau Castalia/OMNeT++ et ont permis de montrer leur intérêt par rapport au contexte applicatif mais aussi par rapport à d?autres protocoles similaires de la littérature.
MEKKI.pdf (9.23 Mo) Télécharger le fichier
tel-01752232 , version 2 (03-11-2016)
tel-01752232 , version 1 (29-03-2018)
  • HAL Id : tel-01752232 , version 2
Kais Mekki. Gestion de l'information embarquée dans des matériaux communicants à l'aide de protocoles de réseaux de capteurs sans fil. Automatique / Robotique. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0034⟩. ⟨tel-01752232v2⟩
323 Consultations
302 Téléchargements
