Contribution à la génération de séquences pour la conduite de systèmes complexes critiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
A contribution to sequences generation for critical complex systems operating
Thomas Cochard
The works presented in this manuscript deals with critical complex systems operation. They are part of the CONNEXION project (Investissements d'Avenir, BGLE2), which involves the main actors in the French nuclear industry around the design of control systems for power plants and their operation. In the operation field, the actions developed by the project concern the engineering phase with the aim of integrating the operator's point of view as soon as possible in the validation of control architectures, and the operation phase with the aim of providing assistance in the preparation and execution of operation procedures. In this context, the contribution presented in this manuscript deals with the generation and verification of action sequences that meet a given objective and that can be safely operated on the process. The proposed approach relies on verifying a reachability property on a network of timed automata modelling the behavior of architectures. The originality is in the definition of a formal modelling framework using patterns promoting the reusability of models, as well as in the proposition of abstraction and reachability iterative analysis algorithms exploiting the intrinsic hierarchization of architectures in order to scale-up of the proposed approach. The contribution was evaluated on the CISPI experimental platform of the CRAN, and on an industrial scale case study proposed within the framework of the CONNEXION project
Les travaux présentés dans ce manuscrit portent sur la conduite de systèmes complexes critiques. Ils s'inscrivent dans le cadre du projet CONNEXION (Investissements d'Avenir, BGLE2) qui réunit les principaux acteurs de la filière nucléaire française autour de la conception des systèmes de contrôle-commande des centrales et de leur exploitation. Dans le domaine de la conduite, les actions développées par le projet concernent la phase d'ingénierie avec pour objectif d'intégrer le point de vue de l'exploitant au plus tôt dans la validation des architectures de contrôle de commande, et la phase d'exploitation avec pour objectif de fournir une aide à la préparation et à l'exécution des procédures de conduite. Dans ce contexte, la contribution présentée dans ce mémoire porte sur la génération et la vérification de séquences d'actions de conduite répondant à un objectif donné et pouvant être opérées en toute sécurité sur le procédé. L'approche proposée repose la vérification d'une propriété d'atteignabilité sur un réseau d'automates temporisés modélisant le comportement des architectures. L'originalité réside dans la définition d’un cadre formel de modélisation sous la forme de patrons favorisant la réutilisabilité des modèles ainsi que dans la proposition d'algorithmes d'abstraction et de recherche d'atteignabilité itératifs exploitant la hiérarchisation intrinsèque des architectures afin de permettre le passage à l'échelle de l'approche proposée. La contribution a été éprouvée sur la plate-forme d'expérimentation CISPI du CRAN puis sur un cas d'étude à échelle industrielle proposé dans le cadre du projet CONNEXION
DDOC_T_2017_0355_COCHARD.pdf (1.79 Mo) Télécharger le fichier
tel-01754706 , version 1 (30-03-2018)
  • HAL Id : tel-01754706 , version 1
Thomas Cochard. Contribution à la génération de séquences pour la conduite de systèmes complexes critiques. Automatique / Robotique. Université de Lorraine, 2017. Français. ⟨NNT : 2017LORR0355⟩. ⟨tel-01754706⟩
197 Consultations
148 Téléchargements
