Random Planar Maps coupled to Spin Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Cartes planaires aléatoires couplées aux systèmes de spins
The aim of this thesis is to improve our understanding of random planar maps decorated by statistical physics models. We examine three particular models using tools coming from analysis, combinatorics and probability. From a geometric perspective, we focus on the interface properties and the local limits of the decorated random maps. The first model defines a family of random quadrangulations of the disk decorated by an O(n)-loop model. After completing the proof of its phase diagram initiated in [BBG12c] (Chap. II), we look into the lengths and the nesting structure of the loops in the non-generic critical phase (Chap. III). We show that these statistics, described as a labeled tree, converge in distribution to an explicit multiplicative cascade when the perimeter of the disk tends to infinity. The second model (Chap. IV) consists of random planar maps decorated by the Fortuin-Kasteleyn percolation. We complete the proof of its local convergence sketched in [She16b] and establish a number of properties of the limit. The third model (Chap. V) is that of random triangulations of the disk decorated by the Ising model. It is closely related to the O(n)-decorated quadrangulation when n=1. We compute explicitly the partition function of the model with Dobrushin boundary conditions at its critical point, in a form ameneable to asymptotics. Using these asymptotics, we study the peeling process along the Ising interface in the limit where the perimeter of the disk tends to infinity.Key words. Random planar map, O(n) loop model, Fortuin-Kasteleyn percolation, Ising model, local limit, interface geometry.
Cette thèse vise à améliorer notre compréhension des cartes planaires aléatoires décorées par les modèles de physique statistique. On examine trois modèles particuliers à l'aide des outils provenant de l'analyse, de la combinatoire et des probabilités. Dans une perspective géométrique, on se concentre sur les propriétés des interfaces et les limites locales des cartes aléatoires décorées. Le premier modèle consiste en une famille de quadrangulations aléatoires du disque décorées par un modèle de boucles O(n). Après avoir complété la preuve de son diagramme de phase initiée par [BBG12c] (chap. II), on étudie les longueurs et la structure d'imbrication des boucles dans la phase critique non-générique (chap. III). On montre que ces statistiques, décrites par un arbre étiqueté, convergent en loi vers une cascade multiplicative explicite lorsque le périmètre du disque tend vers l'infini. Le deuxième modèle (chap. IV) consiste en une carte planaire aléatoire décorée par la percolation de Fortuin-Kasteleyn. On complète la preuve de la convergence du modèle esquissée dans [She16b] et établit un certain nombre de propriétés de la limite. Le troisième modèle (chap. V) est celui des triangulations aléatoires du disque décorées par le modèle d'Ising. Il est étroitement lié au modèle des quadrangulations décorées par un modèle O(n) quand n=1. On calcule explicitement la fonction de partition du modèle muni des conditions au bord de Dobrushin au point critique, sous une forme exploitable pour les asymptotiques. À l'aide de ces asymptotiques, on étudie le processus d'épluchage le long de l'interface d'Ising dans la limite où le périmètre du disque tend vers l'infini. Mots clés. Carte planaire aléatoire, modèle de boucles O(n), percolation de Fortuin-Kasteleyn, modèle d'Ising, limite locale, géométrie d'interfaces.
72023_CHEN_2018_archivage.pdf (2.38 Mo) Télécharger le fichier
tel-01774839 , version 1 (24-04-2018)
  • HAL Id : tel-01774839 , version 1
Linxiao Chen. Random Planar Maps coupled to Spin Systems. Combinatorics [math.CO]. Université Paris Saclay (COmUE), 2018. English. ⟨NNT : 2018SACLS096⟩. ⟨tel-01774839⟩
774 Consultations
275 Téléchargements
