Learning representations from functional MRI data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Apprentissage de représentations en imagerie fonctionnelle
Thanks to the advent of functional brain-imaging technologies, cognitive neuroscience is accumulating maps of neural activity responses to specific tasks or stimuli, or of spontaneous activity. In this work, we consider data from functional Magnetic Resonance Imaging (fMRI), that we study in a machine learning setting: we learn a model of brain activity that should generalize on unseen data. After reviewing the standard fMRI data analysis techniques, we propose new methods and models to benefit from the recently released large fMRI data repositories. Our goal is to learn richer representations of brain activity. We first focus on unsupervised analysis of terabyte-scale fMRI data acquired on subjects at rest (resting-state fMRI). We perform this analysis using matrix factorization. We present new methods for running sparse matrix factorization/dictionary learning on hundreds of fMRI records in reasonable time. Our leading approach relies on introducing randomness in stochastic optimization loops and provides speed-up of an order of magnitude on a variety of settings and datasets. We provide an extended empirical validation of our stochastic subsampling approach, for datasets from fMRI, hyperspectral imaging and collaborative filtering. We derive convergence properties for our algorithm, in a theoretical analysis that reaches beyond the matrix factorization problem. We then turn to work with fMRI data acquired on subject undergoing behavioral protocols (task fMRI). We investigate how to aggregate data from many source studies, acquired with many different protocols, in order to learn more accurate and interpretable decoding models, that predicts stimuli or tasks from brain maps. Our multi-study shared-layer model learns to reduce the dimensionality of input brain images, simultaneously to learning to decode these images from their reduced representation. This fosters transfer learning in between studies, as we learn the undocumented cognitive common aspects that the many fMRI studies share. As a consequence, our multi-study model performs better than single-study decoding. Our approach identifies universally relevant representation of brain activity, supported by a few task-optimized networks learned during model fitting. Finally, on a related topic, we show how to use dynamic programming within end-to-end trained deep networks, with applications in natural language processing.
Grâce aux avancées technologiques dans le domaine de l'imagerie fonctionnelle cérébrale, les neurosciences cognitives accumulent une grande quantité de cartes spatiales décrivant de manière quantitative l'activité neuronale suscitée dans le cerveau humain en réponse à des tâches ou des stimuli spécifiques, ou de manière spontanée. Dans cette thèse, nous nous intéressons particulièrement aux données issues de l'imagerie par résonance magnétique fonctionnelle (IRMf), que nous étudions dans un cadre d'apprentissage statistique. Notre objectif est d'apprendre des modèles d'activité cérébrale à partir des données. Nous proposons différentes nouvelles manières de profiter de la grande quantité de données IRMf disponible. Tout d'abord, nous considérons les données d'IRMf de repos, que nous traitons grâce à des méthodes de factorisation de matrices. Nous présentons de nouvelles méthodes pour calculer en un temps raisonnable une factorisation parcimonieuse de matrices constituées de centaines d'enregistrements d'IRMf. Cela nous permet d'extraire des réseaux fonctionnels à partir de données d'une envergure inédite. Notre méthode principale introduit une réduction aléatoire de la dimension des données dans une boucle d'apprentissage en ligne. L'algorithme proposé converge plus de 10 fois plus vite que les meilleures méthodes existantes, pour différentes configurations et sur plusieurs jeux de données. Nous effectuons une vaste validation expérimentale de notre approche de sous-échantillonnage aléatoire. Nous proposons une étude théorique des propriétés de convergence de notre algorithme. Dans un second temps, nous nous intéressons aux données d'IRMf d'activation. Nous démontrons comment agréger différents études acquises suivant des protocoles distincts afin d'apprendre des modèles joints de décodage plus justes et interprétables. Notre modèle multi-études apprend à réduire la dimension des images cérébrales en entrée en même temps qu'il apprend à les classifier, pour chacune des études, à partir de leurs représentations réduites. Cela suscite un transfert d'information entre les études. En conséquence, notre modèle multi-étude est plus performant que les modèles de décodage appris sur chaque étude séparément. Notre approche identifie une représentation universellement pertinente de l'activité cérébrale, supportée par un petit nombre de réseaux optimisés pour l'identification de tâches.
71188_MENSCH_2018_archivage.pdf (9.09 Mo) Télécharger le fichier
tel-01891633 , version 1 (09-10-2018)
  • HAL Id : tel-01891633 , version 1
Arthur Mensch. Learning representations from functional MRI data. Machine Learning [stat.ML]. Université Paris Saclay (COmUE), 2018. English. ⟨NNT : 2018SACLS300⟩. ⟨tel-01891633⟩
989 Consultations
1089 Téléchargements
