FreeCore : un système d'indexation de résumés de document sur une Table de Hachage Distribuée (DHT) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
FreeCore : an index system of summary of documents on an Distributed Hash Table (DHT)
This thesis examines the problem of indexing and searching in Distributed Hash Table (DHT). It provides a distributed system for storing document summaries based on their content. Concretely, the thesis uses Bloom filters (BF) to represent document summaries and proposes an efficient method for inserting and retrieving documents represented by BFs in an index distributed on a DHT. Content-based storage has a dual advantage. It allows to group similar documents together and to find and retrieve them more quickly at the same by using Bloom filters for keywords searches. However, processing a keyword query represented by a Bloom filter is a difficult operation and requires a mechanism to locate the Bloom filters that represent documents stored in the DHT. Thus, the thesis proposes in a second time, two Bloom filters indexes schemes distributed on DHT. The first proposed index system combines the principles of content-based indexing and inverted lists and addresses the issue of the large amount of data stored by content-based indexes. Indeed, by using Bloom filters with long length, this solution allows to store documents on a large number of servers and to index them using less space. Next, the thesis proposes a second index system that efficiently supports superset queries processing (keywords-queries) using a prefix tree. This solution exploits the distribution of the data and proposes a configurable distribution function that allow to index documents with a balanced binary tree. In this way, documents are distributed efficiently on indexing servers. In addition, the thesis proposes in the third solution, an efficient method for locating documents containing a set of keywords. Compared to solutions of the same category, the latter solution makes it possible to perform subset searches at a lower cost and can be considered as a solid foundation for supersets queries processing on over-dht index systems. Finally, the thesis proposes a prototype of a peer-to-peer system for indexing content and searching by keywords. This prototype, ready to be deployed in a real environment, is experimented with peersim that allowed to measure the theoretical performances of the algorithms developed throughout the thesis.
Cette thèse étudie la problématique de l’indexation et de la recherche dans les tables de hachage distribuées –Distributed Hash Table (DHT). Elle propose un système de stockage distribué des résumés de documents en se basant sur leur contenu. Concrètement, la thèse utilise les Filtre de Blooms (FBs) pour représenter les résumés de documents et propose une méthode efficace d’insertion et de récupération des documents représentés par des FBs dans un index distribué sur une DHT. Le stockage basé sur contenu présente un double avantage, il permet de regrouper les documents similaires afin de les retrouver plus rapidement et en même temps, il permet de retrouver les documents en faisant des recherches par mots-clés en utilisant un FB. Cependant, la résolution d’une requête par mots-clés représentée par un filtre de Bloom constitue une opération complexe, il faut un mécanisme de localisation des filtres de Bloom de la descendance qui représentent des documents stockés dans la DHT. Ainsi, la thèse propose dans un deuxième temps, deux index de filtres de Bloom distribués sur des DHTs. Le premier système d’index proposé combine les principes d’indexation basée sur contenu et de listes inversées et répond à la problématique liée à la grande quantité de données stockée au niveau des index basés sur contenu. En effet, avec l’utilisation des filtres de Bloom de grande longueur, notre solution permet de stocker les documents sur un plus grand nombre de serveurs et de les indexer en utilisant moins d’espace. Ensuite, la thèse propose un deuxième système d’index qui supporte efficacement le traitement des requêtes de sur-ensembles (des requêtes par mots-clés) en utilisant un arbre de préfixes. Cette dernière solution exploite la distribution des données et propose une fonction de répartition paramétrable permettant d’indexer les documents avec un arbre binaire équilibré. De cette manière, les documents sont répartis efficacement sur les serveurs d’indexation. En outre, la thèse propose dans la troisième solution, une méthode efficace de localisation des documents contenant un ensemble de mots-clés donnés. Comparé aux solutions de même catégorie, cette dernière solution permet d’effectuer des recherches de sur-ensembles en un moindre coût et constitue est une base solide pour la recherche de sur-ensembles sur les systèmes d’index construits au-dessus des DHTs. Enfin, la thèse propose le prototype d’un système pair-à-pair pour l’indexation de contenus et la recherche par mots-clés. Ce prototype, prêt à être déployé dans un environnement réel, est expérimenté dans l’environnement de simulation peersim qui a permis de mesurer les performances théoriques des algorithmes développés tout au long de la thèse.
NGOM_Bassirou_these_2018.pdf (4.01 Mo) Télécharger le fichier
tel-01921587 , version 1 (13-11-2018)
tel-01921587 , version 2 (24-01-2020)
  • HAL Id : tel-01921587 , version 2
Bassirou Ngom. FreeCore : un système d'indexation de résumés de document sur une Table de Hachage Distribuée (DHT). Recherche d'information [cs.IR]. Sorbonne Université; Université Cheikh Anta Diop (Dakar), 2018. Français. ⟨NNT : 2018SORUS180⟩. ⟨tel-01921587v2⟩
378 Consultations
479 Téléchargements
