Contribution au développement d’un banc de mesures temporelles 4-canaux pour la caractérisation avancée de composants et de sous-systèmes RF non linéaires - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Contribution to the development of a 4-channel time -domain measurement set-up for advanced characterization of RF non-linear components and subsystems
Lotfi Ayari
  • Fonction : Auteur
The future communications for civil and military applications will use complex wideband modulated signals to be transmitted through multi-channel DOHERTY power amplifiers which should have high performance in terms of power, efficiency, OBO, and bandwidth. In order to meet these stringent requirements, designers need time-domain characterization tools for calibrated measurements and for optimizing voltages and currents at both ports of non-linear connectorized or on-wafer devices. This work successfully implements time-domain characterization tools used to meet specific needs for transistor modeling, to optimize their operation in terms of pulse to pulse stability, and to search optimal conditions of their operation modes in a Doherty power amplifier. For this implementation, mathematical modeling is performed to evaluate sampler’s performances in terms of time-domain sampling efficiency in order to choose the best suited sampling architecture for RF time-domain measurements. Rigorous calibration procedures have been developed to obtain simultaneously full time-domain calibrated waveforms (from low Frequencies to Microwave frequencies).
Les communications futures pour les applications civiles et militaires utilisent des signaux modulés complexes large bande qui seront émis à travers des amplificateurs de puissance multivoie de type DOHERTY qui devront avoir des performances en puissance, rendement, OBO et largeur de bande qui constituent aujourd’hui un véritable défi à relever. Pour ce faire les concepteurs ont besoin d’outils de caractérisation temporelle permettant la mesure normalisées et l’optimisation des tensions et courants aux accès des dispositifs non linéaires sous pointes ou connectorisés. Ce travail de thèse a permis de mettre en œuvre cet outil de caractérisation temporelle qui a été utilisé pour répondre à des besoins spécifiques pour la modélisation de transistor, pour l’optimisation de leur fonctionnement en termes de stabilité impulsion à impulsion, pour la recherche des conditions optimales de leur fonctionnement dans un amplificateur de type Doherty. Pour cette mise en œuvre une modélisation mathématique des échantillonneurs a été réalisée pour évaluer leurs performances et choisir le mieux adapté à la mesure temporelle RF. Des procédures d’étalonnages rigoureuses ont été développées pour obtenir simultanément des formes d’ondes temporelles calibrées à spectre très large (Basse fréquences jusqu’aux Hyperfréquences).
2016LIMO0117.pdf (9.49 Mo) Télécharger le fichier
tel-01958199 , version 1 (17-12-2018)
  • HAL Id : tel-01958199 , version 1
Lotfi Ayari. Contribution au développement d’un banc de mesures temporelles 4-canaux pour la caractérisation avancée de composants et de sous-systèmes RF non linéaires. Electronique. Université de Limoges, 2016. Français. ⟨NNT : 2016LIMO0117⟩. ⟨tel-01958199⟩
107 Consultations
92 Téléchargements
