Control and Estimation in Finite-Time and in Fixed-Time via Implicit Lyapunov Functions - Archive ouverte HAL Access content directly
Theses Year : 2019
Contrôle et Estimation en Temps Fixe et en Temps Fini via Fonctions de Lyapunov Implicites
This work presents new results on analysis and synthesis of finite-time and fixed-time stable systems, a type of dynamical systems where exact convergence to an equilibrium point is guaranteed in a finite amount of time. In the case of fixed-time stable systems, this is moreover achieved with an upper bound on the settling-time that does not depend on the system’s initial condition. Chapters 2 and 3 focus on theoretical contributions; the former presents necessary and sufficient conditions for fixed-time stability of continuous autonomous systems whereas the latter introduces a framework that gathers ISS Lyapunov functions, finite-time and fixed-time stability analysis and the implicit Lyapunov function approach in order to study and determine the robustness of this type of systems. Chapters 4 and 5 deal with more practical aspects, more precisely, the synthesis of finite-time and fixed-time controllers and observers. In Chapter 4, finite-time and fixed-time convergent observers are designed for linear MIMO systems using the implicit approach. In Chapter 5, homogeneity properties and the implicit approach are used to design a fixed-time output controller for the chain of integrators. The results obtained were verified by numerical simulations and Chapter 4 includes performance tests on a rotary pendulum.
Dans ce travail, on montre des nouveaux résultats pour l’analyse et la synthèse des systèmes stables en temps fini et fixe. Ce genre des systèmes convergent exactement à un point d’équilibre dans une quantité du temps qui est fini et, dans le cas de systèmes stables en temps fixe, dans un temps maximal constant qui ne dépend pas des conditions initiales du système. Les chapitres 2 et 3 portent sur des résultats d’analyse ; ce premier present des conditions nécessaires et suffisants pour la stabilité en temps fixe des systèmes autonomes continues tandis que ce dernier combine l’approche de la fonction implicite de Lyapunov avec des résultats de stabilisation ISS pour étudier la robustesse de ce genre de systèmes. Les chapitres 4 et 5 présentent des résultats pratiques liés á la procédure de synthèse des contrôleurs et des observateurs. Le chapitre 4 emploie la méthode de la fonction de Lyapunov implicite afin d’obtenir des observateurs convergents en temps fini et fixe pour les systèmes linéaires MIMO. Le chapitre 5 utilise des propriétés d’homogénéité et des fonctions de Lyapunov implicites pour synthétiser un contrôleur de sortie en temps fixe pour une chaîne d’intégrateurs. Les résultats obtenus ont été validés par des simulations numériques et le chapitre 4 contient des tests de performance sur un pendule rotatif.
these_version_final_BU_deja_valide.pdf (12.18 Mo) Télécharger le fichier
Dates and versions
tel-02071668 , version 1 (18-03-2019)
Identifiers
  • HAL Id : tel-02071668 , version 1
Cite
Francisco Lopez-Ramirez. Control and Estimation in Finite-Time and in Fixed-Time via Implicit Lyapunov Functions. Physics [physics]. Université de Lille, 2019. English. ⟨NNT : ⟩. ⟨tel-02071668⟩
445 View
206 Download
Share
