Microscopic nonlocal potentials for the study of scattering observables of nucleons within the coupled channel framemork - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Potentiels microscopiques non locaux pour l'étude des observables de diffusion de nucléons dans le formalisme des voies couplées
A good understanding and prediction capacity of neutron scattering cross sections is crucial to many nuclear technologies, among which all kinds of reactors based on fission process. For deformed nuclei, the computation of scattering observables for the elastic channel and the first, low-lying excited states requires coupled channel calculations. Local, phenomenological optical and macroscopic transition potentials are the most commonly used in coupled channel analyses, but their accuracy outside of their fitting range remains unpredictable. Microscopic approaches are being developed in order to improve prediction power and solve the extrapolation issue. Potentials obtained microscopically are nonlocal, and recent studies have emphasized the importance of treating explicitly this nonlocality, without using a localization procedure. Our goal in the present work is to study in a quantum framework with no adjustable parameter, the impact of the nonlocality of potentials on scattering observables of nucleon-nucleus reactions. To achieve this we study neutron scattering with the Melbourne G matrix, which represents the interaction between the projectile and one nucleon of the target, and we describe the target’s structure using the RPA for our first applications to ⁹⁰Zr. In order to be able to study also deformed nuclei, we do our study in the coupled channel framework. The first part of this paper is dedicated to the derivation in a unique, consistent scope of coupled equations for nucleon-nucleus scattering and of the potentials obtained with the Melbourne G matrix and RPA structure input. Secondly, we describe the codes which we wrote during this Ph.D. project: MINOLOP for the computation of microscopic potentials using the Melbourne G matrix and structure inputs given in terms of a 1-body density, and ECANOL for the resolution of coupled channel equations using nonlocal potentials as input. Eventually, we present our first applications using these two codes to study pre-equilibrium emissions due to 2-phonon excitations in ⁹⁰Zr.
Une bonne compréhension et une bonne capacité de prédiction de la section efficace de diffusion de neutron est essentielle à un grand nombre de technologies nucléaires, parmi lesquelles les réacteurs à fission. Pour les noyaux déformés, le calcul des observables de diffusion de nucléon pour la voie élastique et les premiers états excités de basse énergie requiert l'utilisation de calcul en voies couplées. Des potentiels optique et de transition phénoménologiques locaux sont le plus couramment utilisés dans les analyses par voies couplées, mais leur précision en dehors de leur domaine d'ajustement est imprévisible. Des approches microscopiques sont en cours de développement pour augmenter les capacités prédictives et résoudre les problèmes d'extrapolation. Un potentiel obtenu microscopiquement est non local, et de récentes études ont souligné l'importance de traiter explicitement cette non localité sans passer par une procédure de localisation. Notre but dans ce travail est d'étudier dans une approche microscopique, sans paramètre ajustable, l'impact de la non localité des potentiels sur les observables de diffusion de nucléon sur noyau cible. Pour ce faire, nous étudions la diffusion de neutron avec la matrice G de Melbourne qui représente l'interaction entre le projectile et un nucléon de la cible, et nous utilisons la RPA pour décrire la structure de la cible dans le cadre de nos premières applications sur le ⁹⁰Zr. Pour pouvoir étudier aussi des noyaux déformés, nous menons notre étude dans le cadre des voies couplées. La première partie de ce document contient la dérivation, faite dans un cadre unique et cohérent, des équations couplées pour la diffusion de nucléons et des potentiels microscopiques obtenues avec la matrice G de Melbourne et une description de la cible via la RPA. La deuxième partie est dédiée à la présentation des codes que nous avons développés durant ce projet de thèse : MINOLOP pour le calcul de potentiels microscopiques à partir de la matrice G de Melbourne et d'informations de structure données sous la forme d'une densité à 1 corps, et ECANOL pour la résolution des équations en voies couplées avec des potentiels non locaux en entrée. Enfin, nous présentons nos premières applications basées sur ces deux codes : l'étude d'émission de pré-équilibre due à des excitations à 2 phonons dans le ⁹⁰Zr.
76406_NASRI_2018_archivage.pdf (2.32 Mo) Télécharger le fichier
tel-02111689 , version 1 (26-04-2019)
  • HAL Id : tel-02111689 , version 1
Amine Nasri. Microscopic nonlocal potentials for the study of scattering observables of nucleons within the coupled channel framemork. Nuclear Theory [nucl-th]. Université Paris Saclay (COmUE), 2018. English. ⟨NNT : 2018SACLS273⟩. ⟨tel-02111689⟩
211 Consultations
351 Téléchargements
