Numerical methods for all-speed flows in fluid-dynamics and non-linear elasticity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Méthodes numériques pour des écoulements multi-régimes en fluidodynamique et élasticité non-linéaire
In this thesis we are concerned with the numerical simulation of compressible materials flows, including gases, liquids and elastic solids. These materials are described by a monolithic Eulerian model of conservation laws, closed by an hyperelastic state law that includes the different behaviours of the considered materials. A novel implicit relaxation scheme to solve compressible flows at all speeds is proposed, with Mach numbers ranging from very small to the order of unity. The scheme is general and has the same formulation for all the considered materials, since a direct dependence on the state law is avoided via the relaxation. It is based on a fully implicit time discretization, easily implemented thanks to the linearity of the transport operator in the relaxation system. The spatial discretization is obtained by a combination of upwind and centered schemes in order to recover the correct numerical viscosity in different Mach regimes. The scheme is validated with one and two dimensional simulations of fluid flows and of deformations of compressible solids. We exploit the domain discretization through Cartesian grids, allowing for massively parallel computations (HPC) that drastically reduce the computational times on 2D test cases. Moreover, the scheme is adapted to the resolution on adaptive grids based on quadtrees, implementing adaptive mesh refinement techinques. The last part of the thesis is devoted to the numerical simulation of heterogeneous multi-material flows. A novel sharp interface method is proposed, with the derivation of implicit equilibrium conditions. The aim of the implicit framework is the solution of weakly compressible and low Mach flows, thus the proposed multi-material conditions are coupled with the implicit relaxation scheme that is solved in the bulk of the flow.
Dans cette thèse on s’intéresse à la simulation numérique d’écoulements des matériaux compressibles, voir fluides et solides élastiques. Les matériaux considérés sont décrits avec un modèle monolithique eulérian, fermé avec une loi d’état hyperélastique qui considère les différents comportements des matériaux. On propose un nouveau schéma de relaxation qui résout les écoulements compressibles dans des différents régimes, avec des nombres de Mach très petits jusqu’à l’ordre 1. Le schéma a une formulation générale qui est la même pour tous le matériaux considérés, parce que il ne dépend pas directement de la loi d’état. Il se base sur une discrétisation complétement implicite, facile à implémenter grâce à la linéarité de l’opérateur de transport du système de relaxation. La discrétisation en espace est donnée par la combinaison de flux upwind et centrés, pour retrouver la correcte viscosité numérique dans les différents régimes. L’utilisation de mailles cartésiennes pour les cas 2D s’adapte bien à une parallélisation massive, qui permet de réduire drastiquement le temps de calcul. De plus, le schéma a été adapté pour la résolution sur des mailles quadtree, pour implémenter l’adaptativité de la maille avec des critères entropiques. La dernière partie de la thèse concerne la simulation numérique d’écoulements multi-matériaux. On a proposé une nouvelle méthode d’interface “sharp”, en dérivant les conditions d’équilibre en implicite. L’objectif est la résolution d’interfaces physiques dans des régimes faiblement compressibles et avec un nombre de Mach faible, donc les conditions multi-matériaux sont couplées au schéma implicite de relaxation.
ABBATE_EMANUELA_2018.pdf (7.4 Mo) Télécharger le fichier
tel-02320972 , version 1 (20-10-2019)
  • HAL Id : tel-02320972 , version 1
Emanuela Abbate. Numerical methods for all-speed flows in fluid-dynamics and non-linear elasticity. Modeling and Simulation. Université de Bordeaux; Università degli studi dell'Insubria (Varese, Italie), 2018. English. ⟨NNT : 2018BORD0409⟩. ⟨tel-02320972⟩
240 Consultations
193 Téléchargements
