Réduction de modèles cinétiques et applications à l'acoustique du bâtiment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Reduction of kinetic models and their application to building acoustics
In this PhD thesis we are interested in the study of different numerical methods for the simulation of high-frequency acoustic problems taking place on the scale of the building. ln the high-frequency approximation the sound propagation can be modeled through a kinetic transport equation paired with the boundary conditions that describe the specular or diffuse nature of the reflections with the boundaries of the demain. ln the first part of this paper we will tackle the resolution of this model, posed in a seven-dimensional space, by the application of the discrete ordinates method. This method consists in the discretisation of the velocity space into a finite number of allowable directions and leads to a system of coupled transport equations having lest ail velocity dependence. Secondly, we will apply the method of moments with entropie closure. The resulting system, of a hyperbolic nature, allows the macroscopic dynamics to be described by only two conservative variables. ln two dimensions, the resolution of these models is performed through a finite volume scheme implemented on GPU. ln three dimensions, a discontinuous Galerkin method is used which can be executed on a hybrid GPU/CPU architecture. For comparative purposes, a particle method has aise been implemented and solved using a fully GPU-parallelised ray-tracing algorithm. Finally, we will apply and compare the developed methods on several test cases specific to room acoustics.
Dans cette thèse nous nous intéressons à différentes méthodes numériques pour la simulation de problèmes acoustiques haute-fréquence prenant place à l'échelle du bâtiment. Dans l'approximation haute-fréquence la propagation du son peut être modélisée par une équation de transport cinétique couplée à des conditions aux bords traduisant la nature spéculaire ou diffuse des réflexions avec les bords du domaine. Dans une première partie et afin de résoudre ce modèle posé dans un espace à sept dimensions, nous lui appliquons la méthode des ordonnées discrètes. Cette méthode consiste à discrétiser l'espace des vitesses en un nombre fini de directions admissibles et conduit à un système d'équations de transport couplées ayant perdu toute dépendance en vitesse. Dans une seconde partie, nous appliquons la méthode des moments avec fermeture entropique. Le système obtenu, de nature hyperbolique, permet de décrire la dynamique macroscopique par deux variables conservatives seulement. En dimension deux d'espace, la résolution de ces modèles est effectuée au travers d'un schéma volumes finis implémenté sur GPU. En dimensions trois d'espace, nous utilisons une méthode Galerkin discontinue exécutable sur architecture hybride GPU/CPU. À des fins comparatives, nous mettons également en place une méthode particulaire que nous résolvons par un algorithme de ray-tracing entièrement parallélisé sur GPU. Enfin, nous appliquons et comparons les méthodes développées sur plusieurs cas tests propres à l'acoustique des salles.
pierre_gerhard_2020_ED269.pdf (3.91 Mo) Télécharger le fichier
tel-02445322 , version 1 (20-01-2020)
tel-02445322 , version 2 (13-02-2020)
tel-02445322 , version 3 (06-04-2020)
  • HAL Id : tel-02445322 , version 3
Pierre Gerhard. Réduction de modèles cinétiques et applications à l'acoustique du bâtiment. Acoustique [physics.class-ph]. Université de Strasbourg, 2020. Français. ⟨NNT : 2020STRAD001⟩. ⟨tel-02445322v3⟩
450 Consultations
202 Téléchargements
