Spatio-temporal data fusion for intelligent vehicle localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Fusion spatio-temporelle de données de localisation pour la navigation autonome
Localization is an essential basic capability for vehicles to be able to navigate autonomously on the road. This can be achieved through already available sensors and new technologies (Iidars, smart cameras). These sensors combined with highly accurate maps result in greater accuracy. In this work, the benefits of storing and reusing information in memory (in data buffers) are explored. Localization systems need to perform a high-frequency estimation, map matching, calibration and error detection. A framework composed of several processing layers is proposed and studied. A main filtering layer estimates the vehicle pose while other layers address the more complex problems. High-frequency state estimation relies on proprioceptive measurements combined with GNSS observations. Calibration is essential to obtain an accurate pose. By keeping state estimates and observations in a buffer, the observation models of these sensors can be calibrated. This is achieved using smoothed estimates in place of a ground truth. Lidars and smart cameras provide measurements that can be used for localization but raise matching issues with map features. In this work, the matching problem is addressed on a spatio-temporal window, resulting in a more detailed pictur of the environment. The state buffer is adjusted using the observations and all possible matches. Although using mapped features for localization enables to reach greater accuracy, this is only true if the map can be trusted. An approach using the post smoothing residuals has been developed to detect changes and either mitigate or reject the affected features.
La localisation précise constitue une brique essentielle permettant aux véhicules de naviguer de manière autonome sur la route. Cela peut être atteint à travers les capteurs déjà existants, de nouvelles technologies (Iidars, caméras intelligentes) et des cartes haute définition. Dans ce travail, l'intérêt d'enregistrer et réutiliser des informations sauvegardées en mémoire est exploré. Les systèmes de localisation doivent permettre une estimation à haute fréquence, des associations de données, de la calibration et de la détection d'erreurs. Une architecture composée de plusieurs couches de traitement est proposée et étudiée. Une couche principale de filtrage estime la pose tandis que les autres couches abordent les problèmes plus complexes. L'estimation d'état haute fréquence repose sur des mesures proprioceptives. La calibration du système est essentielle afin d'obtenir une pose précise. En gardant les états estimés et les observations en mémoire, les modèles d'observation des capteurs peuvent être calibrés à partir des estimations lissées. Les Iidars et les caméras intelligentes fournissent des mesures qui peuvent être utilisées pour la localisation mais soulèvent des problèmes d'association de données. Dans cette thèse, le problème est abordé à travers une fenêtre spatio-temporelle, amenant une image plus détaillée de l'environnement. Le buffer d'états est ajusté avec les observations et toutes les associations possibles. Bien que l'utilisation d'amers cartographiés permette d'améliorer la localisation, cela n'est possible que si la carte est fiable. Une approche utilisant les résidus lissés a posteriori a été développée pour détecter ces changements de carte.
These_UTC_Anthony_Welte.pdf (27 Mo) Télécharger le fichier
tel-03195567 , version 1 (11-04-2021)
  • HAL Id : tel-03195567 , version 1
Anthony Welte. Spatio-temporal data fusion for intelligent vehicle localization. Automatic Control Engineering. Université de Technologie de Compiègne, 2020. English. ⟨NNT : 2020COMP2572⟩. ⟨tel-03195567⟩
398 Consultations
96 Téléchargements
