SEU-Aware Low-Power Memories Using a Multiple Supply Voltage Array Architecture
Abstract : Electric devices should be resilient because reliability issues are increasingly problematic as technology scales down and the supply voltage is lowered. Specifically, the Soft-Error Rate (SER) increases due to the reduced feature size and the reduced charge. This paper describes an adaptive method to lower memory power using a dual Vdd in a column-based Vdd memory with Built-In Current Sensors (BICS). Using our method, we reduce the memory power by about 40% and increase the error immunity of the memory without the significant power overhead as in previous methods.
Document type :
Conference papers
Complete list of metadatas
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01456956
Contributor : Hal Ifip <>
Submitted on : Monday, February 6, 2017 - 10:33:06 AM
Last modification on : Wednesday, August 7, 2019 - 12:18:47 PM
Long-term archiving on: Sunday, May 7, 2017 - 12:43:23 PM
File
978-3-642-45073-0_10_Chapter.p...
Identifiers
Citation
Seokjoong Kim, Matthew Guthaus. SEU-Aware Low-Power Memories Using a Multiple Supply Voltage Array Architecture. 20th International Conference on Very Large Scale Integration (VLSI-SoC), Aug 2012, Santa Cruz, CA, United States. pp.181-195, ⟨10.1007/978-3-642-45073-0_10⟩. ⟨hal-01456956⟩
Share
Metrics
Record views
280
Files downloads
243
