Precision Assembly Technologies and Systems 7th IFIP WG 5.5 International Precision Assembly Seminar, IPAS 2014, Chamonix, France, February 16-18, 2014
Conference papers
Ultrasonic Press–Fitting: A New Assembly Technique
Abstract : The superposition of ultrasonic frequency vibrations to conventional machining techniques is known and practiced since the 1950s under the name of ultrasonic machining. Using ultrasound, many good properties appear including reduced thrust force, improved surface finish, reduced residual stress in machined material, etc…In this paper we present a new assembly technique based on the same principles: ultrasonic press–fitting. Feasibility and energy reduction are demonstrated through experiments under industrial production conditions.
https://hal.inria.fr/hal-01260721
Contributor : Hal Ifip <>
Submitted on : Friday, January 22, 2016 - 3:03:10 PM Last modification on : Monday, October 2, 2017 - 4:06:04 PM Long-term archiving on: : Saturday, April 23, 2016 - 11:02:17 AM
Csaba Laurenczy, Damien Berlie, Jacques Jacot. Ultrasonic Press–Fitting: A New Assembly Technique. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.22-29, ⟨10.1007/978-3-662-45586-9_4⟩. ⟨hal-01260721⟩
