Conference papers
Fault Analysis of Three-Level NPC Inverters in Synchronous Reluctance Motor Drives
Abstract : A performance analysis of a synchronous reluctance motor (SynRM) drive, operating under different fault conditions, with a three-level NPC inverter, controlled by a seven-segment Space Vector Modulation (SVM) technique, is presented in this paper. Considering the voltage source inverter, open-circuit faults of different types are introduced and their effects are studied regarding the SynRM and the inverter performance evaluation. The healthy and faulty operating conditions comparison will take into account the evaluation of some variables, such as the motor power factor, electromagnetic torque, efficiency, total waveform distortion values, currents RMS values, and total waveform oscillation values, obtained from simulation results.
Complete list of metadatas
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01438246
Contributor : Hal Ifip <>
Submitted on : Tuesday, January 17, 2017 - 3:37:51 PM
Last modification on : Tuesday, January 17, 2017 - 3:49:45 PM
Document(s) archivé(s) le : Tuesday, April 18, 2017 - 2:58:47 PM
File
419233_1_En_21_Chapter.pdf
Identifiers
Citation
Diogo Matos, Jorge Estima, Antonio Cardoso. Fault Analysis of Three-Level NPC Inverters in Synchronous Reluctance Motor Drives. 7th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2016, Costa de Caparica, Portugal. pp.206-216, ⟨10.1007/978-3-319-31165-4_21⟩. ⟨hal-01438246⟩
Share
Metrics
Record views
111
Files downloads
238
