System Level Design from HW/SW to Memory for Embedded Systems 5th IFIP TC 10 International Embedded Systems Symposium, IESS 2015 Foz do Iguaçu, Brazil, November 3-6, 2015
Conference papers
Multi-Agent Based Implementation of an Embedded Image Processing System in FPGA for Precision Agriculture Using UAVs
Abstract : This work proposes a framework and design-space exploration on possible implementations for Multi-Agent based embedded systems for precision agriculture applications using image processing. For this application, we evaluate both purely software-based implementations on different embedded processors, as well as implementations which feature dedicated peripherals for image processing implemented in FPGA. All of the implementations feature agent capabilities provided through the JADE Framework. The proposed Reconfigurable hardware Agent framework features capabilities which allow it to offer high performance for applications such as high resolution image processing. We consider the impact of JADE agent migration to an FPGA platform and evaluate the impact of partially reconfiguring the FPGA in this application. The proposed framework is evaluated in an application of use of UAVs for precision agriculture. A faster execution for the image processing algorithms and detection of points of interest (POI) allows for processing images of higher resolution, which may help the accuracy of POI detection. It may also allow for processing an increased number of images in real-time or improve the autonomy of the UAVs.
https://hal.inria.fr/hal-01854156 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 6, 2018 - 3:10:02 PM Last modification on : Monday, August 6, 2018 - 3:12:02 PM Long-term archiving on: : Wednesday, November 7, 2018 - 1:40:08 PM
Érico Nunes, Lucas Behnck, Carlos Pereira. Multi-Agent Based Implementation of an Embedded Image Processing System in FPGA for Precision Agriculture Using UAVs. 5th International Embedded Systems Symposium (IESS), Nov 2015, Foz do Iguaçu, Brazil. pp.15-26, ⟨10.1007/978-3-319-90023-0_2⟩. ⟨hal-01854156⟩
