Formal Techniques for Distributed Systems 12th IFIP WG 6.1 International Conference FMOODS 2010 and 30th IFIP WG 6.1 International Conference FORTE 2010, Amsterdam, The Netherlands, June 7-9, 2010
Conference papers
On Efficient Models for Model Checking Message-Passing Distributed Protocols
Abstract : The complexity of distributed algorithms, such as state machine replication, motivates the use of formal methods to assist correctness verification. The design of the formal model of an algorithm directly affects the efficiency of the analysis. Therefore, it is desirable that this model does not add "unnecessary" complexity to the analysis. In this paper, we consider a general message-passing (MP) model of distributed algorithms and compare different ways of modeling the message traffic. We prove that the different MP models are equivalent with respect to the common properties of distributed algorithms. Therefore, one can select the model which is best suited for the applied verification technique. We consider MP models which differ regarding whether (1) the event of message delivery can be interleaved with other events and (2) a computation event must consume all messages that have been delivered after the last computation event of the same process. For generalized MP distributed protocols and especially focusing on fault-tolerance, we show that our proposed model (without interleaved delivery events and with relaxed semantics of computation events) is significantly more efficient for explicit state model checking. For example, the model size of the Paxos algorithm is 1/13th that of existing equivalent MP models.
https://hal.inria.fr/hal-01055152 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 11, 2014 - 4:27:49 PM Last modification on : Friday, August 11, 2017 - 4:16:34 PM Long-term archiving on: : Wednesday, November 26, 2014 - 10:16:26 PM
Péter Bokor, Marco Serafini, Neeraj Suri. On Efficient Models for Model Checking Message-Passing Distributed Protocols. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.216-223, ⟨10.1007/978-3-642-13464-7_17⟩. ⟨hal-01055152⟩
