Computational methods for hidden Markov tree models - An application to wavelet trees. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2004
The hidden Markov tree models were introduced by Crouse et al. in 1998 for modeling nonindependent, non-Gaussian wavelet transform coefficients. In their paper, they developed the equivalent of the forward-backward algorithm for hidden Markov tree models and called it the 'upward-downward algorithm'. This algorithm is subject to the same numerical limitations as the forward-backward algorithm for hidden Markov chains (HMCs). In this paper, adapting the ideas of Devijver from 1985, we propose a new 'upward-downward' algorithm, which is a true smoothing algorithm and is immune to numerical underflow. Furthermore, we propose a Viterbi-like algorithm for global restoration of the hidden state tree. The contribution of those algorithms as diagnosis tools is illustrated through the modeling of statistical dependencies between wavelet coefficients with a special emphasis on local regularity changes.
hmt.pdf (250.55 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00830078 , version 1 (04-06-2013)
Jean-Baptiste Durand, Paulo Goncalvès, Yann Guédon. Computational methods for hidden Markov tree models - An application to wavelet trees.. IEEE Transactions on Signal Processing, 2004, 52 (9), pp.2551-2560. ⟨10.1109/TSP.2004.832006⟩. ⟨hal-00830078⟩
354 Consultations
1387 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
