Using a biomechanical model for tongue tracking in ultrasound images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose in this paper a new method for tongue tracking in ultrasound images which is based on a biomechanical model of the tongue. The deformation is guided both by points tracked at the surface of the tongue and by inner points of the tongue. Possible uncertainties on the tracked points are handled by the algorithm. Experiments prove that the method is efficient even in case of abrupt movements.
isbms.pdf (1.95 Mo) Télécharger le fichier
ISBMS (1).jpg (65.83 Ko) Télécharger le fichier
Format : Figure, Image
hal-01057861 , version 1 (06-09-2016)
  • HAL Id : hal-01057861 , version 1
Matthieu Loosvelt, Pierre-Frédéric Villard, Marie-Odile Berger. Using a biomechanical model for tongue tracking in ultrasound images. ISBMS - 6th International Symposium on Biomedical Simulation, Oct 2014, Strasbourg, France. ⟨hal-01057861⟩
229 Consultations
407 Téléchargements
