Residual schemes applied to an embedded method expressed on unstructured adapted grids - Archive ouverte HAL Access content directly
Conference Papers Year : 2014
The interest on embedded boundary methods is increasing in Computational Fluid Dynamics because they simplify the mesh generation problem when dealing with the Navier-Stokes equations. To give a few examples, they simplify the simulation of multi-physics flows, the coupling of fluid-solid interactions in situation of large motions or deformations. Nevertheless an accurate treatment of the wall boundary conditions remains an issue of the method. In this work, a penalty term added to the Navier-Stokes equations accounts for the wall boundary conditions and accuracy is recovered using mesh adaptation, thanks to the potential of unstructured meshes.
Not file
Dates and versions
hal-01097482 , version 1 (19-12-2014)
Identifiers
  • HAL Id : hal-01097482 , version 1
Cite
Rémi Abgrall, Hubert Alcin, Héloïse Beaugendre, Cécile Dobrzynski, Léo Nouveau. Residual schemes applied to an embedded method expressed on unstructured adapted grids. Eighth International Conference on Computational Fluid Dynamics (ICCFD8), Jul 2014, Chengdu, China. ⟨hal-01097482⟩
254 View
0 Download
Share
