Simulated Motion Artefact in Computed Tomography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a simulation framework to simulate the computed tomography acquisition process. It includes five components: anatomic data, respiration modelling, automatic parametrisation, X-ray simulation, and tomography reconstruction. It is used to generate motion artefacts in reconstructed CT volumes. Our framework can be used to evaluate CT reconstruction algorithm with motion artefact correction in a controlled environment.
vcbm2015.pdf (1.54 Mo) Télécharger le fichier
Format : Figure, Image
hal-01237833 , version 1 (03-12-2015)
Franck P. Vidal, Pierre-Frédéric Villard. Simulated Motion Artefact in Computed Tomography. Eurographics Workshop on Visual Computing for Biology and Medicine, 2015, Chester, United Kingdom. ⟨10.2312/vcbm.20151228⟩. ⟨hal-01237833⟩
290 Consultations
139 Téléchargements
