Front-tracking by the level-set and the volume penalization methods in a two-phase microfluidic network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Fluids Année : 2016
Two-phase immiscible fluids in a two-dimensional micro-channels network are considered. The incompressible Stokes equations are used to describe the Newtonian fluid flow while the Oldroyd-B rheological model is used to capture the viscoelastic behavior. In order to perform numerical simulations in a complex geometry like a micro-channels network, the volume penalization method is implemented. To follow the interface between the two fluids, the level-set method is used and the dynamics of the contact line is modeled by Cox law. Numerical results show the ability of the method to simulate two-phase flows and to follow properly the contact line between the two immiscible fluids. Finally, simulations with realistic parameters are performed to show the difference when a Newtonian fluid is pushed by a viscoelastic fluid instead of a Newtonian one.
PBT-IJNMF.pdf (3.06 Mo) Télécharger le fichier
hal-01251457 , version 1 (06-01-2016)
Johana Pinilla, Charles-Henri Bruneau, Sandra Tancogne. Front-tracking by the level-set and the volume penalization methods in a two-phase microfluidic network. International Journal for Numerical Methods in Fluids, 2016, 80 (1), pp.23-52. ⟨10.1002/fld.4069⟩. ⟨hal-01251457⟩
152 Consultations
373 Téléchargements
