On the Control of Asynchronous Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The decidability of the distributed version of the Ramadge and Wonham controller synthesis problem, where both the plant and the controllers are modeled as asynchronous automata and the controllers have causal memory is a challenging open problem. There exist three classes of plants for which the existence of a correct controller with causal memory has been shown decidable: when the dependency graph of actions is series-parallel, when the processes are connectedly communicating and when the dependency graph of processes is a tree. We design a class of plants, called decomposable games, with a decidable controller synthesis problem. This provides a unified proof of the three existing decidability results as well as new examples of decidable plants.
TeamcastGames.pdf (358.98 Ko) Télécharger le fichier
hal-01259151 , version 1 (19-01-2016)
hal-01259151 , version 2 (26-01-2016)
hal-01259151 , version 3 (28-01-2016)
hal-01259151 , version 4 (31-01-2016)
hal-01259151 , version 5 (24-10-2016)
hal-01259151 , version 6 (25-10-2016)
hal-01259151 , version 7 (12-12-2016)
hal-01259151 , version 8 (31-01-2017)
hal-01259151 , version 9 (22-04-2017)
hal-01259151 , version 10 (28-07-2017)
hal-01259151 , version 11 (01-08-2017)
hal-01259151 , version 12 (03-08-2017)
Hugo Gimbert. On the Control of Asynchronous Automata. 2017. ⟨hal-01259151v10⟩
343 Consultations
229 Téléchargements
