On the controller synthesis problem for distributed systems with causal memory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
The decidability of the distributed version of the Ramadge and Wonham controller synthesis problem where both the plant and the controllers are modelled as Zielonka automata and the controllers have causal memory is a challenging open problem. There exists three classes of plants for which the existence of a correct controller with causal memory has been shown decidable: when the dependency graph of actions is series-parallel, when the processes are connectedly communicating and when the dependency graph of processes is a tree. We provide a unified proof of these three results, and design a class of plants, called broadcast games, with a decidable controller synthesis problem. This leads to new examples of decidable architectures.
BroadcastGames.pdf (319.25 Ko) Télécharger le fichier
hal-01259151 , version 1 (19-01-2016)
hal-01259151 , version 2 (26-01-2016)
hal-01259151 , version 3 (28-01-2016)
hal-01259151 , version 4 (31-01-2016)
hal-01259151 , version 5 (24-10-2016)
hal-01259151 , version 6 (25-10-2016)
hal-01259151 , version 7 (12-12-2016)
hal-01259151 , version 8 (31-01-2017)
hal-01259151 , version 9 (22-04-2017)
hal-01259151 , version 10 (28-07-2017)
hal-01259151 , version 11 (01-08-2017)
hal-01259151 , version 12 (03-08-2017)
Hugo Gimbert. On the controller synthesis problem for distributed systems with causal memory. 2016. ⟨hal-01259151v5⟩
343 Consultations
229 Téléchargements
