A Class of Zielonka Automata with a Decidable Controller Synthesis Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
The decidability of the distributed version of the Ramadge and Wonham control problem (Ramadge and Wonham 1989), where both the plant and the controllers are modelled as Zielonka au-tomata (Zielonka 1987; Diekert and Rozenberg 1995) is a challenging open problem (Muscholl et al. 2008). There exists three classes of plants for which the existence of a correct controller has been shown decidable in the distributed setting: when the dependency graph of actions is series-parallel, when the processes are connectedly communicating and when the dependency graph of processes is a tree. We generalize these three results by showing that a larger class of plants, called broadcast plants, has a decidable controller synthesis problem. We give new examples of plants for which controller synthesis is decidable.
BroadcastGames.pdf (251 Ko) Télécharger le fichier
hal-01259151 , version 1 (19-01-2016)
hal-01259151 , version 2 (26-01-2016)
hal-01259151 , version 3 (28-01-2016)
hal-01259151 , version 4 (31-01-2016)
hal-01259151 , version 5 (24-10-2016)
hal-01259151 , version 6 (25-10-2016)
hal-01259151 , version 7 (12-12-2016)
hal-01259151 , version 8 (31-01-2017)
hal-01259151 , version 9 (22-04-2017)
hal-01259151 , version 10 (28-07-2017)
hal-01259151 , version 11 (01-08-2017)
hal-01259151 , version 12 (03-08-2017)
Hugo Gimbert. A Class of Zielonka Automata with a Decidable Controller Synthesis Problem. 2016. ⟨hal-01259151v4⟩
343 Consultations
229 Téléchargements
