Notes on Birkhoff-von Neumann decomposition of doubly stochastic matrices
Sur la décomposition de Birkhoff-von Neumann des matrices bistochastiques
Birkhoff-von Neumann (BvN) decomposition of doubly stochastic matrices expresses a double stochastic matrix as a convex combination of a number of permutation matrices. There are known upper and lower bounds for the number of permutation matrices that take part in the BvN decomposition of a given doubly stochastic matrix. We investigate the problem of computing a decomposition with the minimum number of permutation matrices and show that the associated decision problem is strongly NP-complete. We propose a heuristic and investigate it theoretically and experimentally.
