Localization of the $W^{-1,q}$ norm for local a posteriori efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
This paper shows how to localize inside of a domain Ω dual norms of bounded linear functionals on the Sobolev space W^{1,p}_0(Ω). The only condition is that the functional in question vanishes over locally supported test functions from W^{1,p}_0(Ω) which form a partition of unity in Ω, apart from close to the boundary ∂Ω. The results allow in particular to establish local efficiency and robustness for a posteriori analysis of nonlinear partial differential equations in divergence form.
norms_nonlin.pdf (4.97 Mo) Télécharger le fichier
hal-01332481 , version 1 (16-06-2016)
hal-01332481 , version 2 (15-01-2017)
hal-01332481 , version 3 (04-07-2018)
  • HAL Id : hal-01332481 , version 1
Jan Blechta, Josef Málek, Martin Vohralík. Localization of the $W^{-1,q}$ norm for local a posteriori efficiency. 2016. ⟨hal-01332481v1⟩
583 Consultations
758 Téléchargements
