Localization of the $W^{-1,q}$ norm for local a posteriori efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
This paper gives a direct proof of localization of dual norms of bounded linear functionals on the Sobolev space $W^{1,p}_0(\Omega)$. The basic condition is that the functional in question vanishes over locally supported test functions from $W^{1,p}_0(\Omega)$ which form a partition of unity in $\Omega$, apart from close to the boundary $\partial \Omega$. We also study how to weaken this condition. The results allow in particular to establish local efficiency and robustness of a posteriori estimates for nonlinear partial differential equations in divergence form, including the case of inexact solvers.
norms_nonlin.pdf (990.98 Ko) Télécharger le fichier
hal-01332481 , version 1 (16-06-2016)
hal-01332481 , version 2 (15-01-2017)
hal-01332481 , version 3 (04-07-2018)
  • HAL Id : hal-01332481 , version 2
Jan Blechta, Josef Málek, Martin Vohralík. Localization of the $W^{-1,q}$ norm for local a posteriori efficiency. 2016. ⟨hal-01332481v2⟩
583 Consultations
758 Téléchargements
