Efficient Solution of Parameter Dependent Quasiseparable Systems and Computation of Meromorphic Matrix Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Linear Algebra with Applications Année : 2018
In this paper we focus on the solution of shifted quasiseparable systems and of more general parameter dependent matrix equations with quasiseparable representations. We propose an efficient algorithm exploiting the invariance of the quasiseparable structure under diagonal shifting and inversion. This algorithm is applied to compute various functions of matrices. Numerical experiments show the effectiveness of the approach.
bep_r5.pdf (342.3 Ko) Télécharger le fichier
hal-01407857 , version 1 (02-12-2016)
  • HAL Id : hal-01407857 , version 1
Paola Boito, Yuli Eidelman, Luca Gemignani. Efficient Solution of Parameter Dependent Quasiseparable Systems and Computation of Meromorphic Matrix Functions. Numerical Linear Algebra with Applications, 2018, 25 (6), pp.e2141. ⟨hal-01407857⟩
511 Consultations
123 Téléchargements
