Journal articles
Stable broken H1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions
Abstract : We study extensions of piecewise polynomial data prescribed on faces and possibly in elements of a patch of simplices sharing a vertex. In the H1 setting, we look for functions whose jumps across the faces are prescribed, whereas in the H(div) setting, the normal component jumps and the piecewise divergence are prescribed. We show stability in the sense that the minimizers over piecewise polynomial spaces of the same degree as the data are subordinate in the broken energy norm to the minimizers over the whole broken H and H(div) spaces. Our proofs are constructive and yield constants independent of the polynomial degree. One particular application of these results is in a posteriori error analysis, where the present results justify polynomial-degree-robust efficiency of potential and flux reconstructions.
Document type :
Journal articles
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01422204
Contributor : Martin Vohralik Connect in order to contact the contributor
Submitted on : Friday, October 4, 2019 - 12:18:08 PM
Last modification on : Friday, January 21, 2022 - 3:16:34 AM
File
robust_HAL.pdf
Identifiers
Collections
Citation
Alexandre Ern, Martin Vohralík. Stable broken H1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions. Mathematics of Computation, American Mathematical Society, 2020, 89 (322), pp.551-594. ⟨10.1090/mcom/3482⟩. ⟨hal-01422204v4⟩
Share
Metrics
Les métriques sont temporairement indisponibles
