Augmented 3D Catheter Navigation using Constrained Shape from Template - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to overcome the lack of depth perception in fluoroscopic images of endovascolar procedures, we propose a method to retrieve the 3D catheter navigation only having 2D information from x-rays images. The method is based only on image features and real-time constraint-based mechanical simulation.
HSMR17_paper_58.pdf (246.72 Ko) Télécharger le fichier
hal-01545693 , version 1 (23-06-2017)
  • HAL Id : hal-01545693 , version 1
Raffaella Trivisonne, Erwan Kerrien, Stéphane Cotin. Augmented 3D Catheter Navigation using Constrained Shape from Template. Hamlyn Symposium, Jun 2017, London, United Kingdom. ⟨hal-01545693⟩
549 Consultations
477 Téléchargements
