Frequency Domain Forecasting Approach for Latency Reduction in Direct Human-Computer Interaction - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1, 2) , (3) , (3) , (4, 5)
1
2
3
4
5
The problem of latency reduction in direct human-computer interaction is considered and formulated as a trajectory prediction problem. To solve the problem, the predictor is constructed as a frequency-domain approximation of the non-casual ideal predictor. This approximation can be computed analytically, or obtained as an optimization task. An adaptive modification of the forecasting algorithm is proposed taking into account possible variations in user behavior. Experimental results illustrate the applicability of the proposed solution.
FreqPrediction_cdc17_final.pdf (310.29 Ko) Télécharger le fichier
Dates and versions
hal-01651329 , version 1 (28-11-2017)
Identifiers
Cite
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Géry Casiez. Frequency Domain Forecasting Approach for Latency Reduction in Direct Human-Computer Interaction. CDC 2017 - 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. pp.2623-2628, ⟨10.1109/CDC.2017.8264040⟩. ⟨hal-01651329⟩
361 View
233 Download
Share
