A Finite-Difference Method for the Variable Coefficient Poisson Equation on Hierarchical Cartesian Meshes
We consider problems governed by a linear elliptic equation with varying coefficients across internal interfaces. The solution and its normal derivative can undergo significant variations through these internal boundaries. We present a compact finite-difference scheme on a tree-based adaptive grid that can be efficiently solved using a natively parallel data structure. The main idea is to optimize the truncation error of the discretization scheme as a function of the local grid configuration to achieve second-order accuracy. Numerical illustrations are presented in two and three-dimensional configurations. Finite difference method; Hierarchical Cartesian grid; Octree/Quadtree; Variable coefficient Poisson equation 1
