A case study of optimal input-output system with sampled-data control: Ding et al. force and fatigue muscular control model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks and Heterogeneous Media Année : 2019
The objective of this article is to make the analysis of the muscular force response to optimize electrical pulses train using Ding et al. force-fatigue model. A geometric analysis of the dynamics is provided and very preliminary results are presented in the frame of optimal control using a simplified input-output model. In parallel, to take into account the physical constraints of the problem, partial state observation and input restrictions, an optimized pulses train is computed with a model predictive control, where a non-linear observer is used to estimate the state-variables.
genou2018.pdf (1.33 Mo) Télécharger le fichier
hal-01779349 , version 1 (26-04-2018)
hal-01779349 , version 2 (26-04-2018)
Toufik Bakir, Bernard Bonnard, Jérémy Rouot. A case study of optimal input-output system with sampled-data control: Ding et al. force and fatigue muscular control model. Networks and Heterogeneous Media, 2019, 14 (1), pp.79-100. ⟨10.3934/nhm.2019005⟩. ⟨hal-01779349v2⟩
821 Consultations
408 Téléchargements
