Improved Routing on the Delaunay Triangulation
A geometric graph G = (P,E) is a set of points in the plane and edges between pairs of points,
where the weight of the edge is equal to the Euclidean distance between the points. In k-local
routing we find a path through G from a source vertex s to a destination vertex t, using only
knowledge of the present location, the locations of s and t, and the k-neighbourhood of the
current vertex. We present an algorithm for 1-local routing on the Delaunay triangulation, and
show that it finds a path between a source vertex s and a target vertex t that is not longer than
3.56|st|, improving the previous bound of 5.9.
bestchord.pdf (1.35 Mo)
Télécharger le fichier
Format : Figure, Image
