Genetic and environmental dissection of biomass accumulation in multi-genotype maize canopies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Experimental Botany Année : 2019
Multi-genotype canopies are frequent in phenotyping experiments and are of increasing interest in agriculture. Radiation interception efficiency (RIE) and radiation use efficiency (RUE) have low heritabilities in such canopies. We propose a revised Monteith equation that identifies environmental and genetic components of RIE and RUE. An environmental term, a component of RIE, characterizes the effect of the presence or absence of neighbours on light interception. The ability of a given plant to compete with its neighbours is then identified, which accounts for the genetic variability of RIE of plants having similar leaf areas. This method was used in three experiments in a phenotyping platform with 765 plants of 255 maize hybrids. As expected, the heritability of the environmental term was near zero, whereas that of the competitiveness term increased with phenological stage, resulting in the identification of quantitative trait loci. In the same way, RUE was dissected as an effect of intercepted light and a genetic term. This approach was used for predicting the behaviour of individual genotypes in virtual multi-genotype canopies. A large effect of competitiveness was observed in multi-genotype but not in single-genotype canopies, resulting in a bias for genotype comparisons in breeding fields.
ery309(1).pdf (1.73 Mo) Télécharger le fichier
hal-01895279 , version 1 (15-10-2018)
Paternité
Tsu-Wei Chen, Llorenç Cabrera-Bosquet, Santiago Alvarez Prado, Raphael Perez, Simon Artzet, et al.. Genetic and environmental dissection of biomass accumulation in multi-genotype maize canopies. Journal of Experimental Botany, 2019, 70 (9), pp.2523-2534. ⟨10.1093/jxb/ery309⟩. ⟨hal-01895279⟩
461 Consultations
157 Téléchargements
