A Convex Approach to the Finite Dimensional Matching Problem in Communication Systems
In this work, the impedance matching problem in communication systems is formulated as a convex optimization problem. Important properties of the problem including feasibility, existence and uniqueness of solution are discussed. A practical example of matching filter synthesis using this technique is presented.
Mots clés
Matching Network
Matched filters
Communication networks
Antennas
Convex Optimisation
Semi definite programming
Matching problem
Filtering theory
Reflection coefficients
Impedance matching
Analytic interpolation
Optimisation problem
Schur functions
Positive semidefinite matrices
Positive polynomials
Pick matrices
