A switched dynamic model for pointing tasks with a computer mouse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asian Journal of Control Année : 2020
In this paper, we study one of the most fundamental tasks in human‐computer interaction, the pointing task. It can be described simply as reaching a target with a cursor starting from an initial position (e.g. executing a movement using a computer mouse to select an icon). In this paper, a switched dynamic model is proposed to handle cursor movements in indirect pointing tasks. The model contains a ballistic movement phase governed by a nonlinear model in Lurie form and a corrective movement phase described by a linear visual‐feedback system. The stability of the model is first established and the derived model is then validated with experimental data acquired in a pointing task with a mouse. It is established that the measured data of pointing movements of different types can be fitted within the proposed model. Numerical comparison against pointing models available in the literature is also provided.
pointing_model_final_hal.pdf (488.91 Ko) Télécharger le fichier
hal-02083760 , version 1 (03-05-2019)
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Géry Casiez. A switched dynamic model for pointing tasks with a computer mouse. Asian Journal of Control, 2020, 22 (4), pp.1387-1400. ⟨10.1002/asjc.2063⟩. ⟨hal-02083760⟩
278 Consultations
356 Téléchargements
