Journal articles
A NURBS-based Discontinuous Galerkin method for conservation laws with high-order moving meshes
Abstract : The objective of the present work is to develop a new numerical framework for simulations including moving bodies, in the specific context of high-order meshes consistent with Computer-Aided Design (CAD) representations. Thus, the proposed approach combines ideas from isogeometric analysis, able to handle exactly CAD-based geometries, and Discontinuous Galerkin (DG) methods with an Arbitrary Lagrangian-Eulerian (ALE) formulation , able to solve complex problems with moving grids. The resulting approach is a DG method based on rational Bézier elements, that can be easily constructed from Non-Uniform Rational B-Splines (NURBS), formulated in a general ALE setting. We focus here on applications in compressible aerodynamics, but the method could be applied to other models. Two verification exercises are conducted, to assess rigorously the properties of the method and the convergence rates for representations up to sixth order. Finally, two problems are analysed in depth, involving compressible Euler and Navier-Stokes equations , for an oscillating cylinder and a pitching airfoil. In particular, the convergence of flow characteristics is investigated, as well as the impact of using curved boundaries in the context of deformable domains.
Keywords : OPAL-Meso
Complete list of metadata
https://hal.inria.fr/hal-02887312
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Wednesday, January 6, 2021 - 11:09:48 AM
Last modification on : Friday, January 21, 2022 - 11:28:02 AM
File
JCP_2021.pdf
Identifiers
  • HAL Id : hal-02887312, version 2
Collections
Citation
Stefano Pezzano, Régis Duvigneau. A NURBS-based Discontinuous Galerkin method for conservation laws with high-order moving meshes. Journal of Computational Physics, Elsevier, 2021, 434 (1). ⟨hal-02887312v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
