Decomposition of High Dimensional Aggregative Stochastic Control Problems
We consider the framework of high dimensional stochastic control problem, in which the controls are aggregated in the cost function. As first contribution we introduce a modified problem, whose optimal control is under some reasonable assumptions an ε-optimal solution of the original problem. As second contribution, we present a decentralized algorithm whose convergence to the solution of the modified problem is established. Finally, we study the application to a problem of coordination of energy consumption and production of domestic appliances.
high_dimensional_stochastic_problem_18_08_2020.pdf (607.32 Ko)
Télécharger le fichier
