IO-SETS: Simple and efficient approaches for I/O bandwidth management
One of the main performance issues faced by high-
performance computing platforms is the congestion caused by
concurrent I/O from applications. When this happens, the
platform’s overall performance and utilization are harmed. From the
extensive work in this field, I/O scheduling is the essential solution
to this problem. The main drawback of current techniques is
the amount of information needed about applications, which
compromises their applicability. In this paper, we propose a
novel method for I/O management, IO-SETS. We present its
potential through a scheduling heuristic called SET-10, which
is simple and requires only minimal information. Our extensive
experimental campaign shows the importance of IO-SETS and
the robustness of SET-10 under various workloads. In particular
in most of the simulated scenarios we improve the I/O slowdown
over fairshare by 50%, which corresponds in our scenarios to a
platform utilization gain of 2.5%. In the practical scenarios that
we did, the utilization gain varies between 10 and 30%. We also
provide insights on using our proposal in practice.
main.pdf (3.34 Mo)
Télécharger le fichier
supp (1).pdf (724.17 Ko)
Licence : CC BY - Paternité
