Variational inference via Wasserstein gradient flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Inférence variationnelle via les flots de gradient Wasserstein
Along with Markov chain Monte Carlo (mcmc) methods, variational inference (vi) has emerged as a central computational approach to large-scale Bayesian inference. Rather than sampling from the true posterior π, vi aims at producing a simple but effective approximation π to π for which summary statistics are easy to compute. However, unlike the well-studied mcmc methodology, algorithmic guarantees for vi are still relatively less well-understood. In this work, we propose principled methods for vi, in which π is taken to be a Gaussian or a mixture of Gaussians, which rest upon the theory of gradient flows on the Bures-Wasserstein space of Gaussian measures. Akin to mcmc, it comes with strong theoretical guarantees when π is log-concave.
Bures-JKO_v3.pdf (2.14 Mo) Télécharger le fichier
hal-03953336 , version 1 (24-01-2023)
Marc Lambert, Sinho Chewi, Francis S Bach, Silvère Bonnabel, Philippe Rigollet. Variational inference via Wasserstein gradient flows. NeurIPS 2022 - Thirty-sixth Conference on Neural Information Processing Systems, Nov 2022, Nouvelle Orléans (Louisiane), United States. ⟨10.48550/arXiv.2205.15902⟩. ⟨hal-03953336⟩
76 Consultations
183 Téléchargements
