VRPSolverEasy: a Python library for the exact solution of a rich vehicle routing problem - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... (Preprint) Year : 2023
The optimization community has made significant progress in solving Vehicle Routing Problems (VRPs) to optimality using sophisticated Branch-Cut-and-Price (BCP) algorithms. VRPSolver is a BCP algorithm with excellent performance in many VRP variants. However, its complex underlying mathematical model makes it hardly accessible to routing practitioners. To address this, VRPSolverEasy provides a Python interface to VRPSolver that does not require any knowledge of Mixed Integer Programming modeling. Instead, routing problems are defined in terms of familiar elements such as depots, customers, links, and vehicle types. VRPSolverEasy can handle several popular VRP variants and arbitrary combinations of them.
main-clear.pdf (455.37 Ko) Télécharger le fichier
Dates and versions
hal-04057985 , version 1 (04-04-2023)
hal-04057985 , version 2 (05-04-2023)
Identifiers
  • HAL Id : hal-04057985 , version 2
Cite
Najib Errami, Eduardo Queiroga, Ruslan Sadykov, Eduardo Uchoa. VRPSolverEasy: a Python library for the exact solution of a rich vehicle routing problem. 2023. ⟨hal-04057985v2⟩
291 View
1782 Download
Share
