SmolPhone: a smartphone with energy limits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper explores the smartphone design space to achieve energy sobriety. At its core, the proposed platform has a compute-limited but energy efficient microcontroller (MCU). Another processor can be attached to execute legacy Linux applications. Some tasks are offloaded to the Wi-Fi network controller. Our design prefers an energy-efficient variant of the 4G cellular network, which is turned off as often as possible. We are in the process of designing a hardware evaluation board to implement the vision presented in this paper.
smolphone.pdf (146.42 Ko) Télécharger le fichier
smolphone-IGSC23.pdf (1.95 Mo) Télécharger le fichier
hal-04156447 , version 1 (08-07-2023)
hal-04156447 , version 2 (18-09-2023)
hal-04156447 , version 3 (28-10-2023)
Paternité
  • HAL Id : hal-04156447 , version 3
Joseph Paturel, Clément Quinson, Martin Quinson, Simon Rokicki. SmolPhone: a smartphone with energy limits. IGSC 2023 - 14th International Green and Sustainable Computing, C. Mani Krishna; Michele Magno, Oct 2023, Toronto, Canada. pp.4. ⟨hal-04156447v3⟩
416 Consultations
378 Téléchargements
